The problem in brief. S320 diesel (07 plate) with Brabus gubbins (factory fitted) will behave perfectly until I use about half throttle when it throws all the toys out of the pram and goes into limp mode.
MB independent have no idea, I have even less. Things checked so far after STAR reported low fuel rail pressure.
All sensors and wiring
Fuel pump lines and filter
Injectors and leak back
Everything passed but three injectors were at the very bottom of the specs and I was advised to change them. Three new Bosch injectors, one big bill and there is no difference.
Could the Brabus unit be faulty and will it help to remove it?
Any tips or pointers will be much appreciated.
Brew
Brew
