CreepyCoupe
Even in ECO mode.Should I be worried
I’d be worried if it didn’t![]()
Me too.I thought they pulled away in second in ECO mode. Something about more comfort. And 1st in sport mode
Huh?I’d be worried if it didn’t![]()
Are you talking about manuals?Know that on a basic 5-speed transmission, the shifter's resting position is in neutral directly between 3rd & 4th gear. Thus, to find 1st & 2nd, you have to pull the shifter toward you. For 5th & reverse, you have to push the shifter away from you. For 3rd & 4th, release the shifter and simply push or pull the shifter to find the gear. To go from 2nd to 3rd for example, simply nudge the shifter out of 2nd into neutral--slight pause--and then push the shifter forward and it will go directly into 3rd. As well, take some time and dry shift to practice getting the gears.
I think he was trying to RTFM.Are you talking about manuals?
Unless in Winter or snow type mode or manual lock up, all auto cars start in 1st. They may only stay in first for a split second but the box has to start somewhere till the gearchange system knows what situation it's in. (on flat ground, going uphill etc). What would be the point in a first gear otherwise. The ECO mode just moves the upshift change points to get to top gear as soon as possible to save fuel and also controls the "stop/start" function on certain models.
Know that on a basic 5-speed transmission, the shifter's resting position is in neutral directly between 3rd & 4th gear. Thus, to find 1st & 2nd, you have to pull the shifter toward you. For 5th & reverse, you have to push the shifter away from you. For 3rd & 4th, release the shifter and simply push or pull the shifter to find Nox Vidmate VLC the gear. To go from 2nd to 3rd for example, simply nudge the shifter out of 2nd into neutral--slight pause--and then push the shifter forward and it will go directly into 3rd. As well, take some time and dry shift to practice getting the gears.
yes i talk on thisAre you talking about manuals?
Hmmm! The plot thickens. Thanks for your reply.My previous car a 2014 E300 Hybrid with 7 speed auto always started in first gear never ever in second gear regardless of driving mode.
My current car a 2016 E350 with 9 speed auto is the same it has never started in second gear and using the paddle shifters will not allow second to be selected regardless again of driving mode.
Robin
