Jacking points
babyblueCE
300 CE
Morning all. I have an enquiry regarding jacking points. If i was to use the jacking points to jack the car where would be a suitable location for me to place the axle stands? Also if i didnt use the jacking points to jack the car up from where would be a suitable place to jack the car from? I have a 300CE.
jacking up the car using the hidden jacking tubes (behind removable covers)
you would then place the support stand under the rubber bushes which are located nearby each jacking tube.
Put your head down and you will see (and can feel) them under the car.
If your using a trolley jack place it under the center of the engine cross member at the front, and under the differential at the rear. Then as kth has said place support stands under the rubber blocks.
