I've owned an XF SV8 for around 18 months and an XFR for 2 years.
What year are you looking at?
What to look for:
Think that's about it for problems! When they don't have any of the above problems they are a great car, I've had two, however I found the customer service to be lacking.
- With the car locked and the remote fobs out of range try opening all the doors. If one/more open then the door lock mechanism needs replacing.
- If it's a premium model check all of the door card tops as the manufacture did a poor job of gluing it down and in cold weather it lifts and looks horrible Door cards January 2017
- The rear brakes can wear out faster than the fronts due to the stability control system so check they have some meat on them.
- Check all of the windows go down fully and can be returned to fully closed a few times. The window mechanisms can go crazy and it gets tricky to return the widow to fully closed without it returning to fully open by itself.
- Older cars are known to de-laminate around the edge of the windscreen.
- Some of the wheel types are quite soft so check for any damage.
- The parking sensors can fail which causes the parking camera to become unavailable. Put the car in reverse a few times as it can be intermittent.
- Check all four rotating air vents in the dash work as the mechanism can fail due to being cheap plastic. Only requires a couple of quid part however the dash needs pulling apart to get to it.
- On the test drive keep an ear out for a rattle in the front door cards. The window mechanism in older cars uses a rubbish foam around the cables that degrades over time and you get a metallic rattle on rough roads.
- Check the emergency door lock handle cover on the front passenger side as it can become loose over time and may need replacement.
- The petrol cap mechanism on the older cars is not great and can get stuck so try opening and closing a few times.
- There is a plastic trim on the front seats that can crack when lets say the larger of the human race use the car for a period of time Imgur
- The petrol tanks can be noisy as they don't have sufficient baffles to prevent the fuel from sloshing about.
- Rattle in dash from centre speaker that I never was able to solve on my old car.
- Check the front and rear heated screens work as occasionally they can fail / be very poor.
- If you are looking at the 3 litre diesel get someone to check the air inlet manifold 'Restricted Performance' would normally be displayed in the dash when putting your foot down. They are made of plastic and can crack, not cheap to fix.
Wow! Thanks so much for the detailed response. What a cracking couple of cars you’ve had, I love the red one!
Thanks everyone.
The search has started!! Found a few on Autotrader and been ringing around. Will also look on some JAG forums
