James Leigh, Merton.
jeffwebb
Orihuela, Spain./ London, England.
E55 AMG + Suzuki Burgman 400
Some of you will have seen my post in " Engine" referring to a strange noise I have been hearing. Following a B service by a nearby "specialist" I was told it was bearings in the gearbox and a new box was required at a cost of £1500. They had confirmed this by running the car up on a ramp and using a stethoscope on the box. Being a cynical person I took it to James Leigh in Merton for a second opinion. Turned out the handbrake cable was rubbing on the propshaft which he fixed for nothing, together with a fuse which had blown. All done in 20 minutes. Can't recommend him highly enough. Saved me a load of money which a gullible person would have paid out.:rolleyes:
Anyone in the SW London area should give them a try.
It is such a common fault that.
We used to see at leat one a week at the dealer.
What handbrake cable rubbing on propshaft ?
That sounds like a really bad design if that happens :crazy:
Nice to hear it's been fixed for little money.
Obviously the original Inde. isn't to be trusted, I doubt a dealer would have pulled such a stunt.
because it is a dispute between two parties and one may be biased against the other and naming and shaming could just be part of a scheming plot.
Understandably.
James is a down to earth person, good to talk, knowledgeble and explains the options...i recommend james leigh strongly
