Hi all,
Hoping you can help as google hasn't yielded much.
I own a 2013 C220 CDI BlueEff. While driving the other day (after filling up), car began to suddenly jerk upon acceleration. Pulled over switched off and switched on again, same problem. Eventually by the time i'd got to where i was going the EML was on.
I checked while car not in gear, idle is ok between 770 and 800, but when accelerator down it can jump up and down constantly. In limp mode, i noticed that car was extremely underpowered (compared to previous limp modes) i.e. 5-10 mph uphill.
Scanned car with icarsoft and its giving
P0236 - Boost Pressure Sensor Malfunction (circuit 'A' on OBDC)
P2279 - Intake air system Leak
I've had the P2279 before, so set about checking intercooler hoses, no leak. Found residue beneath pipe going from air box to turbo (when checked, pipe was fine, no cracks, think this was from a previous episode where the jubilee clip needed tightening, but open to checking more). Checked air filter and nothing amiss. Cleaned boost sensor and it seemed to help (a little).
Cleared code and tried again and this time got code:
P0299 - The boost pressure of turbo 1 deviates from the specified value at low engine speed
Did a live read of data
B28/5 Pressure sensor downstream of air filter - 1.01 bar
B5/1 Boost Pressure Sensor - Between 0.57 and 0.62 bar
B60 Exhaust Back Pressure Sensor - 1.15 bar
B28/8 DPF diff pressure sensor - 0.02 bar
Y77/1 Boost Pressure Positioner - 47.11%
Degree of Contamination of Air Filter - 0%
I'm on the verge of pulling the trigger on a new boost pressure sensor, but thought i'd ask the question first. The two codes don't show up together on many google searches for the OM651 engine.
Please help! Tearing my hair out this close to xmas!
