esprit200
- May 11, 2003
- 2002 CLK500
Hello!
I have a combined problem on my CLK270 CDI (2002).
The car is equipped with the sport brake kit with larger calipers (4 piston?) and larger drilled discs as per CLK55. I have two problems;
1. Heavy judder under braking
2. I drive forwards and apply the brakes, I then drive in reverse and apply the brakes, I hear a loud *clack* on first application of the brakes, as if the pads have shunted in the caliper. The same applies when changing from reverse to forward direction. The noise only occurs on the first application of the brakes.
Are these problems related or coincidental? 1. I would presume is warped discs, 2. I am more puzzled by.
Any input?
Regards,
Jon.
Any input?
Regards,
Jon.
