I have a problem of the car juddering for a few moments at certain speeds. It always does it as you accelerate through 40mph and sometimes (but much less often) at other speeds, for example about 20mph and occasionally at 70mph. I feel it is getting worse. The juddering is felt through the steering wheel, and is feels like driving over a poor concrete road surface. When it first started I did put it down to the road surface.
The garage at first couldn't reproduce the judder - not clear why not because it is *always* there at 40mph and when they finally did, suggested changing the great gearbox mountings. This might have improved the problem slightly for a couple of weeks, but not sure about that.
This is an E-320CDI, with airmatic suspension, and properly serviced and 100,000 miles. It makes no difference if the drive is in W or S, although the point where it judders may change slightly.
The dealer doesn't see to know what to do.
Wasn't sure if I should post here or in suspension, so apologies if I am in the wrong place.
Can anyone give any help or guidance please?
