I suspect that the off side front disc/brake is warped on the W203 – when I apply the brakes there is a heavy judder from the front off side wheel.
I washed the car on Monday but did allow just under half an hr for the brakes/wheels to cool down – the harder I have to brake from acceleration/speed the worse the vibration/judder is.
The alloy wheels are fine and not been buckled or kerbed on any way.
Would you all agree that it is most likely a warped disc/brake causing the judder from what I have described?
