Didn't really know where to put this as I am unsure what is causing the juddering.
So, driving back to Bristol form Southampton a couple of weeks ago, had the first experience of juddering going all through the car. Got the car home and took it to my local tyre fitters who inspected the front tyres, which were found to have bulges in the side walls, to ensure this was the problem, the front wheels and back wheels were changed over. Problem seemed to be resolved so bought 2 new tyres. The tyres with bulges in were runflats, and had also worn significantly on the inside edges of both tyres about 25mm or so. I then had a full steering geometry check, first time since I owned the car although I have had the tracking checked regularly, the camber angle was way off which resulted in the tracking going way off when the camber angle was adjusted.
So, today, all was going well, took the car from Bristol to Bath, then up the A46 to the M4, along the M4 to M5 south to Cribbs Causeway, no problems. Driving from Cribbs Causeway to home, the juddering started again and I had to pull in as I thought I had a flat tyre. I have since then had the car inspected by F1Autos who looked at the tyres, did a short MoT inspection on the suspension to check for anything loose, but all is ok. Drove back from F1Autos and the car was fine.
Anyone any ideas what could be causing an intermittent problem like this? I have the car booked in with my Indie on Monday and would possibly like to give him some suggestions.
