Jump point under bonnet ???
micky13
Gillingham Kent UK
C280 w202 and 280S w108 A class w169
Hi, I have a 1997 c280 w202 . Could anyone tell me where abouts under the bonnet the jump point is. As my battery is totally flat and am unable to get into boot unless I remove back seats. Thanks for your time. Mick
Make sure you make a good contact with your battery charger or jump lead clips.
Key fob should open boot, internal dash central locking switches won’t work unless the key is turned in ignition, (once power is connected up key should turn in ignition)
The Negative – lead is on the engine lifting eye.
Dec
Cheers DEC all sorted now great stuff.
