Hi Guys,
Having a slight issue with my 2010 e350 CDI jumping into park at slow speeds. Could the issue be down to the battery not holding charge and low voltage? Im wondering this as before it happened I was sat in the car with music on without the engine running for a quite while. When it happens, if I rev car high for a while it stays in drive when selected. I'm in the process of checking the main battery (waiting for a tester to arrive tomorrow).
I have looked at the service menu on dash and checked voltage and amps. UB hovers around 14.7 - IB fluctuates massively...engine off -7.6A , engine running flies up to 60+ A then settles around 6.5 amp with comand, air etc all turned off. (New alternator fitted very recently btw).
If it is likely to be a battery issue would it be the main battery or the Aux Battery?
Note: No faults on dash!
Thanks in advance for any assistance.
