Just querying an engine fitment
NW_Merc
Banned
Over here, sometimes over there
1994 Mercedes C180 classic
Is it possible to fit an engine from a car with a manual transmission to one with an automatic? Say I had a C230K with a manual transmission but wanted to transfer the engine to another car with an automatic for example.
nick mercedes
far far away
Ford Expedition
Yes a straight swap, spigot bearing will need to come out though (easy enough).
jaymanek
Nuneaton Warwickshire
err hold on, an auto box on a modernish car like that will need wiring vacuum pipes and maybe other gubbins depending on age.
OP
OP
NW_Merc
NW_Merc
Banned
Yes, sorry I didnt mention ancilliaries, I was just asking that if both cars were side by side could the manual engine be made to fit an auto box
grober
MB Master
Perth, Scotland
W204 C200CDI Estate
If its one of the electronic 5 speed autos the gearbox ECU may need to communicate with the main engine ECU--- which is coded to the ignition switch etc [ depending on age] The engine ECU's may be different also between the auto and manual boxes. Different advance curves/wiring loom etc. If you are talking about an older design 4 speed hydraulic box things will be easier but may require minor changes to the throttle linkage and a vacuum line from the inlet manifold and some wiring changes for the gear select mechanism.
MarkJunedd
Swansea
98 CLK320 Sport
I may be wrong but I cant see how the ecu's etc would be an issue. If i understand you correctly your wanting to use the engine out of a manual car into an automatic car with a defunct engine. Engine out, couple of bits to swap , engine in . Should be easy ,its not like youre trying to convert a manual car to automatic or vise versa, then you probably would have issues with the ecu's.
nick mercedes
far far away
Ford Expedition
Exactly, a straight forward swap over.
