derekpayne
I've had an intermittent fault with my CLS 320, where when I go to accelerate hard, the engine feels like it's cutting out repeatedly and the car is very very jerky, if I release the throttle back it accelerates fine, it just caught me out every now and again, also sometimes I would lose turbo boost altogether and the only way to get it back would be to stop, turn the engine off, remove the key and start it again.
Anyway, I borrowed an OBD reader (mine didn't show any faults and the engine management light never came on) which went deeper into the system, and several faults emerged, some historical but 1 in particular caught my eye, "2510-1 Stored & Current, Check component Y77/1 (Boost pressure regulator). Positioner signals fault".
I googled this code and found that it related to the turbo regulator, I removed the whole component, (remove the air intake bat wing, remove the turbo heat shield, remove the circlip holding the arm to the regulator lever and 3 bolts holding the regulator to the turbo, disconnect the electrical plug. there are six clips holding the black cover onto the body of the regulator which can be removed with a small screwdriver, inside you can see a number of tiny, and I mean TINY wires from the outside of the cover to the PCB, I had already replaced 2 of them previously, but on this occasion I found one wire detached from its soldered connection.
In order to solder a new wire you need to remove the zinc coating on the joints, this I did with my Precision grinder (dremel type tool), once the zinc was removed showing the clean surface I soldered another slightly thicker wire to this connection and tested continuity.
After fitting everything back I gave it a good thrashing up the road, that was 3 days ago, and I have tried ever since to make it do the "Kangaroo" action but t is as smooth as it should be, I will borrow that OBD scanner again soon and check to see if the code is still there.
That particular fault has been with me for a few years, and because my own scanner never showed anything I was clueless as to what was causing it.
So far so good.
Cheers
Derek
So far so good.
Cheers
Derek
