blueserenity777
My W203 keyfob is not working now..Accidentally stuck it in my wash as it was in the pocket..It also then ended up in the dryer for about 40mins still in the pants pocket..
Have replaced the 2 CR2025 Varta batteries..still not working..Tried swapping the batteries accross to the spare key to check..battery is fine..Spare key Battery section in the washed keyfob..it does not work..so circuit board issue..tried blowing out if any water in there..still nto working..
Is there any way of getting this repaired..need a spare set..WHAT ARE MY OPTIONS NOW..bec of key coding issue..
HELP..
HELP..
