Spare key problem (which was sitting in the bag as spare one and was not used at all for couple of years) - it does lock and unlock the car, but I can't start the engine with it (changed battery`s to new ones - i tought fault is in batterys). There is that noise comming out from key port when you are inserting key - small buzz and you can turn egnition on - normally, but this key even don't make that buzzing noise at all. If this key wasn`t from my car I'm pretty sure it even won't lock/unlock doors.
I`ve been adviced - if you are not using key for some time period it can loose code to start engine and have to be re-programmed for around £250. Is this true or not? Is there any other way how to sort this out?
I don`t have problem with "main key" - it unlocks/locks the car and I`m able to switch engintion on. Only this key was used by previous owner on daily basis untill I bought the car.
Thanks in advance!
Thanks in advance!
