markm730
My keyfob is intermittently working and wandered how easy it is to change the battery in them.
When the car is left overnight or for a long period throughout the day the fob will work ok for opening the car , ignition and start up also fine. After use and when required to lock up it won’t operate and I’m left with the option of locking passenger door manually and using the actual key to lock drivers door. As I found out a few days ago this method doesn’t lock the boot!!
I’ve had a look at the fob and it doesn’t look like it comes apart in any way to get inside. Is there a way to replace battery without taking it to a garage.
Thanks in advance
Thanks in advance
