It may of been the way i was explaining the parts.
I have tested the key fobs (buttons on the key that supposed tonlock unlock etc.) and they make the noise through the fm radio when slowly tuned.......showing (as best as possible) the key fobs work.
The alarm siren (mounted near the windscreen) is currently disconnected (3wire plug) ...... if I connect it weather the car is locked or unlocked the siren goes off continuously. Only way to stop is disconnect.
With the siren disconnected, I can press the "lock" button on the center console and the car will lock, after 30seconds ish the indicators flash to show an alarm activation (including the little red led in the dash) whilst this is happening I can still turn the key and start the car. It takes approximately 5mins then all the flashing stops and doesn't repeat
(unless I use the button in the car again)
Hopefully this is a bit clearer.
I have checked as many fuses as I can see, is there one inline to the alarm module (brain) that is hidden somewhere?
