key not working away from car?
Discussion in 'Electronics' started by Olivier, Oct 21, 2011.
  1. Olivier
    Olivier Hardcore MB Enthusiast
    1,666
    Oct 30, 2008
    Edinburgh
    Car:
    E300 TD
    I got a fob that work fine to open or close the doors as long as I am pointing it to the driver door handle, but as soon as I am a bit away or not pointing it to the handle it won't work. The batteries are new.
    The other fob is fine to open and close the doors further away.
    Any hint on what to do?
    Cheers.
    Olivier
  2. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,741
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    Car:
    C43 AMG with a 55 engine and supercharger, E55 AMG, S500, etc
    New key methinks.
    1 person likes this.
  3. longhoughtonlad
    longhoughtonlad Active Member
    88
    Aug 21, 2011
    North Northumberland
    Car:
    C180, SL 320. Freelander2 2012
    Yep, just had the very same pleasure :wallbash: £189 from **** Turpin. This was for key and IR unit:)
  4. OP
    OP
    Olivier
    1,666
    Oct 30, 2008
    Edinburgh
    Car:
    E300 TD
    Cheers.
    Nothing to tinker with then? There are 2 signals is it? And one is not doing its job?
    No way I pay for a new key. I got 3 keys, one work fine, the other is missing one signal from what I can gather and the other is the flat one that just start the car.
    Anyone played with those to see if anything can be done?
  5. enasseguapy
    enasseguapy New Member
    1
    Oct 29, 2011
    Car:
    enasseguapy
  6. Spin_bowler
    Spin_bowler Hardcore MB Enthusiast
    1,341
    Sep 1, 2006
    Hertfordshire
    Car:
    LR Discovery, Audi A4 Avant, Smart For Two
    ^^that's easy for you to say...
  7. Liwi
    Liwi Active Member
    64
    Aug 22, 2011
    Car:
    Nada
    Not sure if this is going to work but on Audis, when changing your batteries, you need to reset it.
    On Audis you put the key in the ignition and press lock and unlock button a few times.
    I heard on MB's it is a bit different but you could try all..
    You could try to put the key in the ignition and push the lock button on your key fob, pull the key out while holding down the lock button and press the unlock button 5 times. Your key should now be reset and ready for use
    or...
    Put the key in ignition (needs to be turned on) and the car started before pressing and holding lock then pressing unlock five times
Tags:
Share This Page
