Key problems
CLK CHAZ
Mansfield UK
CLK 350 Sport CAB
Hi
Went to the car yesterday and opened it with my main key in my pocket using the keyless go feature. whilst in the car it flashed up key not recognized a couple of times but the car drove fine. When i stoped and got out i could not lock it via the keyless button and the key was totaly dead. Will it just need a new battery or is the key knackered. My spare key works fine. I never use the key in the ignition, it did have a new battery at the dealer under a year ago. Any thoughts guys.
Chaz
OP
OP
CLK CHAZ
CLK CHAZ
Mansfield UK
CLK 350 Sport CAB
Hi Guys
Has anyone got any idea. Thanks
Chaz
IanW
Reading
W209 CLK 500
Probably just needs new batteries, but I found mine was more reliable once I bent the battery retaining arm in the key fob down a little. It looks like it gets a tad loose with age. Like most things I guess...
Ian.
crockers
North Wilts
XC60 MY2014 SeLux Nav plus lot and lots of toys...
Thanks Ian i hope so dont fancy spending £250 on a new key.
regards Chaz
If your car is under 3 years old and the key has failed it should be covered under the warranty. If all it needs is a battery then that isn't too expensive.
