Key Refurb
AL3X
C63 AMG
The YouTube videos are pretty accurate, however one of them doesn’t mention the fact the key is glued amongst other bits, bare with me I will put together a small guide
OP
OP
S
Scaramanga
Thanks so much! Mine is the two battery version though. Is yours the one battery one ?
AL3X
C63 AMG
Right, so I suggest following these instructions along with watching the YouTube videos.
First of all you need to remove the key blade and then use this to pop the battery cover off:
Once this is done I used a blade or similar to lever the top chrome piece off, the retaining clip is on the left hand side if looking at the key from the back, but there is no way to access this to ‘unlock’ it so just be a little gentle and it will come free:
The key release slider will come off with this and you’ll be left with the below:
Next is the tricky bit of removing the chrome side pieces, they can be quite tight and although YouTube videos show to lever them from the bottom, I found this was going to mark the plastic, and found the best was was to lodge a piece of paracetamol casing between the chrome piece and retaining clip, then lever with a screwdriver from the top:
Do the same for the other side, you may find the retaining clip is harder to see but it is there.
The next part involves breaking the plastic casing apart as it is glued together from factory, I found the best way was to start at the top end where the chrome top piece will cover:
Gently work your way around until the casing is open.
The next part is somewhat difficult as the circuit board is almost plastic welded to the casing, this needs to be heated and delicately removed and the same done when you’ve swapped the board into the new housing:
Reassembly is the reverse of the above, I glued around the seam of the casing with some loctite gel superglue before reassembling and held it together loosely with the chrome side pieces whilst it dried.
The finished product:
Any questions I’ll be happy to help.
OP
OP
S
Scaramanga
Yes, keyless. Will that make it harder ?
unimog
Derbyshire
W203 C350, AMG GT63s Coupe 4dr
I have the old black key fobs with my W203, its an '06 saffa built one so it must have been the absolute last... one is playing up now despite new batteries so I was wondering if I can use the newer type, does anyone know if its possible?
DjBlaze
London
Mercedes CLK 280
Hi All, I am hoping I can upgrade my Mercedes Benz CLK 280 2006 Coupe with new key fobs case to chrome shell as both keys badly need a refurb.
Please could someone let me know if this is possible with my CLK 280 2006? if someone could point me in the right direction of who to contact to do this at a good price I would be really grateful?
Many thanks - B
