Hi, having a right mare with my duff ignition barrel. Tried to remove with 2mm wire etc no luck, took the car to a local merc specialist but their special tool didn't work (first time ever apparently) and was quoted £3-400 to drill it out
On the plus side the key still does go round so I can line the two holes up (key won't come out now so lucky its on the drive!)
Would drilling the black plastic sleeve to expose the barrel be my best bet?
Thanks for any advice, I need it!
