keyless door problems
agshull
Hull
mercedes e class
keyless handle on drivers door will not open when you try the handle
but will still lock ok when you press the button, the key has got a new battery in it and all the other doors work fine, any ideas?
A likely cause to your problem is the door handle itself. They aren't the most sturdy of handles and because the drivers handle gets used most frequently, it tends to wear out first.
