triumphboy
Hi all
I have an intermittent issue with the keyless start on my CLS55. I have had it looked at by a Mercedes specialist who says there is no fault showing up on the Star diagnostics.
The symptoms are, that if the car is left for a while, say overnight, the keyless start (and stop) will usually work (even a number of times in a row) - before you drive anywhere. However, once driven any distance, more often that not, you cannot then shut the engine off with the start(stop) button, you need to use the key in the ignition to stop the engine. From that point, occasionally it will start again with the keyless button, but most other times it won't and you need to use the key in the ignition.
I have put new batteries in the key, which didn't make any difference.
I'm at a bit of a loss as to what to do now. Does anyone have any suggestions as to what might be going on, or what else I can do to diagnose the fault please? Thank you
