Kickdown throttle sticking c180 w203
Discussion in 'Engine' started by dinomax, Oct 2, 2011.
  1. dinomax
    dinomax New Member
    12
    Nov 10, 2009
    DERBY
    Car:
    C180 W203
    Hi All
    My W203 C180 (2000) has developed a serious problem with the throttle sticking. Driving back from local shops last week throttle suddendly jammed...........went past my house at 140MPH with very braking doing very little. fortunately there is a field with a steep encline nearby managed to get it out of the residential area and onto the field (meant going round a roundabout at about 100mph). It has only done it once since then and this time i noticed it's when the kickdown is depressed.
    any ideas guys ?
  2. Auto-mobile
    Auto-mobile MB Enthusiast
    1,600
    Oct 1, 2011
    Birmingham
    Car:
    2x c43 Amg clio 172 turbo 314bhp
    Replace the pedal complete, I have had it on w210's its drive by wire so there nothing else that would cause it
  3. Alex Crow
    Alex Crow Active Member
    278
    Sep 30, 2011
    Super Suffolk
    Car:
    S210 320cdi
    very odd that, normally using the brakes kills the throttle...
  4. Anders
    Anders Active Member
    467
    Feb 11, 2004
    Brussels, Belgium
    Car:
    ‘14 BMW X5 M50D
    It did 140 mph and negotiated a roundabout at 100 mph...? :thumb: Well done, clearly a very fit C180 and your driving skills are not too shabby either! :rolleyes:
    1 person likes this.
  5. OP
    OP
    dinomax
    dinomax New Member
    12
    Nov 10, 2009
    DERBY
    Car:
    C180 W203
    Thanks Fella.........But I did have to crawl home and change my underwear immediately.
    Any ideas what could be causing this ?
  6. Alex Crow
    278
    Sep 30, 2011
    Super Suffolk
    Car:
    S210 320cdi
    Dinomax, if I am to take your posts seriously you have been lucky to escape with your life.
    The only sensible advice I can give you is to have the car recovered to a workshop ASAP, and not to drive it again until it has been fixed by a proffessional.
  7. davionix
    davionix New Member
    19
    Feb 11, 2011
    angus,scotland
    Car:
    e220 cdi blue efficiency
    what a frightening situation,i am intrigued how this can happen so please forgive my ignorance when i say would it not have been possible to shove the gearstick into neutral and then turn off the ignition?
    As someone has said this is a potentially fatal accident waiting to happen!
  8. OP
    OP
    dinomax
    dinomax New Member
    12
    Nov 10, 2009
    DERBY
    Car:
    C180 W203
    Thanks Davionix.......This was no joke, fortunately i live in the English countryside. there is a vary large roundabout at the end of my street wich leads to either the M1 Motorway or a couple of smaller exits, one goes to more residential areas or the other to farmland fields. I managed to get the farmland exit (I think did exactly what you descbribed). I fumbled with the gears until i felt the engine had disengaged and frantically tried to turn the ignition off. What is the most confusing is why when I restarted the car it was as if nothing had ever happened ?????????
    Until I next had to press down the kickdown and this re-occured, luckilly i was in a remote part of the country and it didn't catch me by surpise this time.
    I think I'll bust out the WD40 and grease this weekend and empty it on the throttle mechanism and re-grease. if this fails it will be a trip to the MB stealership next week. it's never cheap when diagnonsis is involved (they basically wright thier own cheques
    Unless anyone has any suggestions.
  9. Alex Crow
    278
    Sep 30, 2011
    Super Suffolk
    Car:
    S210 320cdi
    I have a suggestion, DO NOT DRIVE IT AT ALL until it has been repaired by a Mercedes repair specialist.
    I offer this suggestion for all the right reasons - never play with life threatening faults.
  10. davionix
    davionix New Member
    19
    Feb 11, 2011
    angus,scotland
    Car:
    thanks for the info,I can only strongly agree with alex crows advice,its too dangerous not to!
Share This Page
