00ormes
Hi all,
Ive recently discovered a knocking noise coming from my 2010 w212 e250 from the front end of my car.
After reading quite a few threads i found there wasn't much out there matching my fault and its symptoms.
The knocking stopped when applying the brakes and seemed** to go when i sped up.
The fault was ill fitted pads which the dealer is changing and is now also replacing the two front disks
Hopefully this video helps anyone with the same issue.
(The microphone slightly picks up the knocking)
[YOUTUBE HD][/YOUTUBE HD]https://youtu.be/Zo44dVamgxg[YOUTUBE HD][/YOUTUBE HD]
