Lack of power
babyblueCE
300 CE
Hello all. My C124 doesn't rev above 4000rpm and I can't seem to get it to go more than 70mph. Does anyone know why this could be?
My brother once bought a nearly new 306 diesel in 1995, which had a similar problem. He was so annoyed for a whole weekend. Turned out to be the rubber mat had slipped underneath throttle pedal not allowing it to be fully depressed.
Stone me, that's a first for me. My problems have always been sub-10 mph. 70+ an absolute dream.
My impression of all my MBs is that they are AOK for Autobahn and, well, forget Stadtmitte.
Sorry to have no suggestions.
RayH
I've actually had a new fuel filter fitted in just recently
If this model has a MAF sensor I would start there.
Problems started after the new filter was put in. I will check if it's back to front and will also check the maf sensor as well
300CE with a MAF? If this car is a real 300 and not a 320, it should have KE Jetronic and a 'mechanical' MAF.
Best to clarify exactly which car we're thinking about here.
RayH
So here's my dilemma. The mechanic I used installed the filter back to front now the nozzle at the front of this pic needs to go on the other side. I cant remove this one so I need to if buy a new one. Before I do that is the front nozzle easily removed?
Photos of the filter
Undo the bolt at the top and put it on the bottom. It is simple to do but I cant remember if it is reverse threaded or not.
After looking at the arrows on the body of the filter maybe its time for a mechanic change!
Tony.
I did all that and in the process the top fuel pump has started to leak think I tweaked when installing the filter. Going the replace the whole lot with new filter and pumps.
