putbinoot
Ok people am i going mad, had a check engine light so scanned car and got G3/2 upstream open circuit, now this is my first mistake i did not come here and ask first i looked at a picture on line that had a v6 showing two exhausts and 4 sensors so i ordered 2 upstream sensors thought might as well do both. Get under car to find only one exhaust and what looks like a downstream sensor anyway take it out put new one in and cleared fault which lasted an hour then came back with thrust value to high so i'm assuming the sensor i got is wrong one. So to the point finally i have a 2007 E320cdi 3.0 v6 with what appears to be only one sensor and its after the cat but every where i look it only mentions sensors before cat did they change it on the face lift am i going mad. Sensor i took of has part number 0258017016, has anyone changed there's and found what i have. Thanks for any input.
