Laptop help
Beetnik
Yorkshire
Volvo V60 2.4 bi-turbo: SLK 200
Dell Vostro laptop won't boot.
Switch on.
Fan starts.
Fan stops.
Num lock key flashes on and off rapidly and repeatedly.
Nothing else.
Have:
Cleaned keyboard.
Removed/reinstalled RAM
Removed/reinstalled HD
No change.
What next (get credit card out!!)
Silly question but are you plugged into mains.
It could be the battery is shot so will need mains power.
If its not beeping then the memory should be ok. The flashing could be worth googling as that could mean something on a Dell
Looking at this it could be the RAM, how much has it got and how many slots?
If it has say 512mb * 2 slots take one out and try it. Then the other and put the first one back in the slot.
Other than that it could be as above a mianboard issue and on a laptop unless you want to get busy with tiny screws and cables almost new laptop time :(
Surely you didn't manage to spill something on it ?
Your house insurance won't be chuffed ................
<joke mode OFF>
Try booting from Mains with memory and hdd removed. Count number of num lock flashes and report back with your service tag number from the bottom of the machine. I'll see if I can help you.
Have tried booting from mains with memory and hdd removed, both with and without battery inserted. Same old same old - Num lock flashes constantly and doesn't stop. I'm guessing the motherboard has gone.
Service tag isn't readable any more but Express service Code is: 380662385. It's a Vostro 1320, 32 bit running Win 7 Ultimate (or not running at all!!).
I bought a few of these and have another defunct one in the office - missing keyboard keys - so may try and swap components out to recover hdd contents.
Sounds like it is then. You could try reseating the cpu if you haven't already done this.
Perhaps this might help swapping out the bits if you haven't got it...........
Documentation
Best of luck.
