Large Parasitic Draw on Battery
Discussion in 'Electronics' started by Voyager, Feb 8, 2014.
  1. Voyager
    Voyager Active Member
    123
    Oct 31, 2008
    Hi
    My car is a 2001 S210 E320 cdi estate
    Last week the garage diagnosed a large 18Amp draw on the battery when the car was shut down and after tess concluded it was the Alternator.
    The Alternator was replaced and the car was picked up at 6pm yesterday. At 9pm yesterday the alarm went off; when I went out to investigate, the battery was dead. Something is still drawing charge when car is shut-down and locked??
    100% sure no doors, windows of lights had been left on.
    Does anyone have an idea what could be wrong please ? (The battery is only 8 weeks old and alternator is new).:wallbash:
    thanks......
  2. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,412
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    It could be one of many things.
    The only way to do it is to place an ammeter in series at battery and pull fuses until you see current draw drop.. Any decent garage can do this.
    1 person likes this.
  3. jamesfuller
    jamesfuller MB Enthusiast
    1,171
    Aug 14, 2013
    Northamptonshire
    Car:
    The one that starts!
    Its not usually difficult to find a draw, just time consuming. Are you going to look into it yourself or take it back to the the garage?
  4. Sp!ke
    Sp!ke Administrator
    12,234
    Jun 2, 2002
    West London
    Car:
    SL500 & The Fart Car
    This sort of thing is best left to a vehicle electrical specialist or you could be chasing your tail for a while.
    If you have a decent multimeter and some electrical know how you could remove the fuses one by one whilst measuring the current draw on the battery (with everything off and the doors shut).
    This would pinpoint which circuit the problem lies, allowing you to investigate further.
    18 amps is huge...
  5. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,922
    Feb 8, 2007
    Portsmouth, Hampshire.
    Car:
    E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
    I expect it to be a preheater of some kind with that kind of draw.
    No need for a electrical specialist. Any decent MB independent can do it.
  6. OP
    OP
    Voyager
    123
    Oct 31, 2008
    yes, the garage did check all the fuses and non were faulty. was just the alternator that was drawing power - hence the replacement........but must be something else - or something intermittent.........?
  7. OP
    OP
    Voyager
    123
    Oct 31, 2008
    yes, agree - must have a heating element to draw that amount.
  8. Ted
    Ted MB Enthusiast
    5,758
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    At well over 200 watts something is getting pretty hot. Shouldn't be too hard to find.
  9. V12
    V12 MB Enthusiast
    5,610
    Jun 17, 2002
    Southampton
    Car:
    S320CDI LWB
    Open the bonnet and look to your left hand side, you'll see 2 black tank looking things.
    From memory, furthest to the left is water expansion tank for radiator and the other is the electric booster heater. I'm pretty sure this is fed power directly from the alternator point but seeing as it is basically a kettle element and that it draws it's power from the alternator point it would be my first port.
    Unplug it and see what happens.
    I replaced the unit on my W210 320cdi, it was an easy swap. Mine wasn't draining the battery but was completely dead.
  10. OP
    OP
    Voyager
    123
    Oct 31, 2008
    take it back to the garage
  11. BlackC55
    18,922
    Feb 8, 2007
    Car:
    The alternator will never cause a current draw. Why did they replace that!
    Go somewhere else.
  12. moonloops
    moonloops MB Enthusiast
    5,312
    Oct 8, 2009
    :Location : Location
    Car:
    W204 C350 CDI AMG Sport
    ^^This^^
    Best advice, same as I followed a while back and easily found the culprit.
  13. jaymanek
    16,412
    Nov 29, 2002
    Car:
    The alternator may not have been charging properly? Those water cooled alternators do commonly fail.
  14. grober
    grober MB Master
    27,913
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Have you got heated seats?
  15. Deadly Dave
    Deadly Dave Active Member
    279
    Oct 16, 2010
    Dublin, Ireland
    Car:
    1988 300CE & 1965 230SL
    It will if diodes fail in the regulator.
  16. brucemillar
    brucemillar MB Enthusiast
    8,663
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    and.. If you alternator was toast? Whatever is causing this draw maybe about to toast your new alternator.
Share This Page
