Largest Tyre Width C63 Coupe
C63PTL
Bath
C63 COUPE
Hi
Looking to change my wheels to 8 1/2J & 9 1/2J, would it be ok to run 235/35 front & 265/30 rear without any rubbing?
Is anybody running with these sizes or bigger?
Cheers Paul
automaniaman
Nelsons County
Yes one of those
The fronts will be fine, the rears will be dependant on offset, my 9.5 J ET 45s do ground the wheel arches occasionally under load...
OP
OP
C63PTL
C63PTL
Bath
C63 COUPE
Thanks for that, what if i run standard offset on the rear which i think is 54? i take it you rear offset is 45 which is what the front offset is on a standard car.
automaniaman
Nelsons County
Yes one of those
If you run the oem rims with 265s on the rear you'll be fine, the problem is the after market 9.5 J rims all seem to come with ET45.
OP
OP
C63PTL
C63PTL
Bath
C63 COUPE
Ok. Thanks for that,:thumb: ill have to see if i can get the right offset in the wheels i like. fingers crossed.
almoamg
Scotland
RS6
If you get the right offset it should be fine. I run 10" with 275s on rear, no rubbing but also depends on tyre brand. e.g. GoodYear F1's rub, Michelin PSS don't.
