- Nov 1, 2008
- Location
- Bournemouth/Poole Dorset
- W210 E280 x2, w211 E55, W212 E63 biturbo, S204 C180K
Just recovering from a very fraught 24hrs due to my perceived plumbling skills that went terribly wrong.
Picture this......I'm in the process of decorating the kitchen and at one end is a radiator that needs to be removed to get behind it to prepare and emulsion the wall. I've done this dozens of times before, shut off both valves, undo, drain rad into a bucket and put to one side.
This time however, I stupidly forgot to hold tight to the 2nd valve as the nut was unscrewed from the radiator. The valve tilted and I spotted water leaking and thought it may have been a bit loose and gave it an extra tighten up.
The leak grew stronger and with Screwfix only 100 yds from home, I literally ran down and got a new valve to replace this one. I had damaged the olive and it needed fixing..quickly.
2nd mistake.... With the rad out of the way, I now had a valve sitting at 45 degrees to the tail and water gushing out. Shouted to the missus to help and she found me with my thumb over a now exposed tail that was pumping water in a jet at the ceiling. The valve had literall dropped off leaving the damaged olive on the pipe and me unable to attach the new valve and olive.
I'm now kneeling in a pool of water and thinking what to do for the best. The missus got towels and tried to halt the flow whilst I went to the shed, got out the step ladder and went into the roof space to raise the float in the expansion tank and stop any further water entering the heating system.
This was where I made mistake number 3, which I'll return to later.
So I return to the kitchen to find Mrs AMGeed absolutely soaked and panicking. I went outside, pulled out the garden hose and hoped I could get the end over the exposed pipe and drain down the system. I had a spare lenght of 15mm copper pipe and there seemed no way this was going over the leaking pipe.
I may have redeemed myself a little by switching on the kettle, boiling it and pouring boiling water over the end of the hose.
Evacuating the missus, I managed to get the hose attached to the leak and away drained the water.
We were two drowned rats and the kitchen was a mess of water. I have taken 3 lumps of skin off the end of my thumbs plugging that razor sharp pipe. I send the missus off to get out of her wet clothes whist the water drains down I'll make a cuppa!
A shout from upstairs.......water is pouring though the back bedroom ceiling and light fitting , soaking a double bed and carpet. WTF!
I raced back into the loft space to find in my haste to close off the water earlier, I had accidentally trodden on the leak off pipe to the hot water tank. My mistake No 3. The boiler at that time was still heating the water, and I had a split the copper pipe, sending hot water into the voids between the floor joists.:fail
Another panic, and I got some duct tape wrapped around the leak which finally stopped it. Meanwhile, the wife has placed containers to collect water running across the bedroom ceiling and trying to prevent it reaching the living room. Too late! Its now dripping slightly on to the old carpet being replaced next week. More containers out and at last all the leaks stop. The bedroom light is turned off, but the light is flashing and crackling.
That was last night. This morning, onto Bank of Scotland emergency insurance (thank you lordy for me buying it) and a plumber is here within 2 hrs of my call. I have already cut the old olive off, refitted the valve and connected up the radiator, refilled the system and bled it. Everything is good.
One compression fitting of a stop valve and the plumber is done. About £120 if called out without insurance he tells me. The bill is settled already by BOS.
So its been a stressful 24hrs domestically, but now I have to wait until Monday to call BOS again and claim for bed, carpet, duvet and ceiling repair on my home insurance. First time ever in 30 years I have claimed but it feels good to think I'm getting some of my premiums back.
Don't ask if you need plumbing assistance from me. My reply may offend
Thanks for sticking to the end.
