Darrell
Hardcore MB Enthusiast
- Dec 15, 2006
- Gixxer 6, Citroen Berlingo, 911 C4S, Dacia Duster and lots of bicycles.
No, I was a sod in my youth!Happytalk73 said:You're wild Darrell.
Will, Its not what's known as" good working practice' its certainly not ," normal practice," its for the most part unnecessay and, unsightly, and for a Plumbing and Heating Contractor, absolutely uneconomic. Imagine you have a contract to supply and fit the Plumbing &Heating to 20 new builds, each property has 10 rads, that's two ballofixes to each =20 x20 houses = at £1 each £400 even before you pay your plumber for the extra time taken to fit an unnecessary fitting.If one of my Plumbers ever came up with a stroke like this, he'd have been back home before lunch.On the other hand, I do understand your reason for doing this in your own property, as you no doubt find it makes things easier for you. I could go on but need to lie down for a bit.
happytalk73 said:is this your work darrell?
Will, Will, Will. I did say in my piece above, (last two lines) that I do understand your reason for doing this, etc, etc,,,,,,,,,,,,,,,,,,,
I don't get the reason for the isolating valves. Surely the radiator valves themselves are the only isolating valves you need?
will said:i've never met a poor plumber! :d
Its a plumbing term ffs!Darrell said:Or Joey, fiddling with his "ball ****"
And ffs is a plumbers term/phrase.
And there lies the problem!crockers said:To a layman who has no plumbing skills i thought Wills isolation valves a great idea....
