I need to get power from the house to the garage and ideally a water supply too, the distance is about 40ft.
I understand that the cable has to be buried about 18 inches below the surface and inside a suitable pipe.
Can a water pipe be buried in the same way? (in a seperate protective pipe obviously). Does it need to be insultated to prevent freezing or will it be fine so long as it's far enough below the surface?
