Darren1dazza
Hi wondering if anyone can help not long had my e280 seen a few posts about the joint between the turbo and air feed leaking and causing oil dripping if this pipes cracked or split would it cause a lot off oil to leak after driving and hitting boost I’ve seen a repair kit but just wondering if this would be the problem causing the leak and a lot of smoke cheers Darren
