thamesc180k
hello all, can someone explain how the oil stop harnesses for the leaking magnetic cam sensors work?
does the oil run along the outside of the wires insulation, to say the ecu, and cause damage/short circuits?
if the sensors leak from their housings can one "bung" a gasket sealant around the housing, to stop it leaking, rather than buying new ones?
Surely the oil must seep around the outside of the sensors and not internally as they would be sealed?
Thanks , just trying to understand what the issue is.
