GlenQ
In late July this year i purchased a set of two 'Error Free White LED W5W Sidelights For Various MB Models' from a member here.
The lamps were promptly dispatched and upon recept I proceded to install them following the installation instructions included. After fitting I noticed that one of the lamps was flashing on and off while the other one was fully working. After turning the sidelights on and off a few times the flashing one turned on and seemed to be OK.
Later that day I emailed the seller and explaned the situation and said that I would monitor the LED lamp over the comming weeks and report if I had any more problems. The seller emailed back with further advice and instructions which I followed.
Since then I have not used the car much as I work from home and due to the time of year I did not use my headlights until recently. Now when I turn on the sidelights I get a lamp failure warning and the same lamp is not lit.
Again I emailed the seller and told him of the problem and he replied that the lamps only carry a one month warranty from the time of purchase (no warranty period is mentioned in the add for the lamps) therefore the lamp would NOT be replaced.
I did point out that I had informed him of a possible problem with the lamp a couple of days after I had received it but he remaind unmoved and is refusing to replace the lamp because my last email is outside the one month warranty period.
I think the after sales policy is poor from a member selling to another member on this forum. If I had only recently informed the seller of the problem fair enough, but he was aware of a possible intermittent fault with the lamp within one week of purchase.
I don't think the lamps have a problem when used with Mercedes cars I just think I have a problem with one of mine which I think was present before I received it.
Obviously the £7.50 cost of one lamp means more to him than customer satisfaction.
The upshot of this is that I have now replaced both of the LED's with OEM filiment lamps and now both sidelights work with no errors reported.
If any other member here has installed these lamps and would like a working spare PM me and I will gladly send my remaining working lamp FOC.
Please note:
I have no other axe to grind with the seller and have NOT fallen out with him I just think his customer service leaves a lot to be desired. I will not be drawn into a flame war about this, the above facts are true and I will NOT comment further other than via PM. This is just my experiance when buying parts from a fellow forum member.
Please note:
