smokebelch
- Feb 18, 2015
- CLS 320cdi
well after owning the car approximately 23 hrs I got in it this afternoon to be greeted by the engine management light glowing merrily at me!!!!
Took it to a local specialist who plugged it in to his Star tester
summary
intake air temperature sensor
Right hot film mass air flow sensor (the air mass is too small)
Right hot film mass air flow sensor (short circuit or open circuit)
Left hot film mass air flow sensor (the air mass is too small)
Left hot film mass air flow sensor (short circuit or open circuit)
Mass airflow sensor. The mass air flow sensor is faulty
Mass airflow sensor. Sensor right. The air mass is too small
Mass air flow sensor. Sensor left. The air mass is too small
Glow plug cyclinder 4 open circuit
N14/3 at least one of the glow plugs is not actuated
Communication fault between CDI control unit
Test signal line (circuit 61) Signal line is interrupted
Heating check component. Short circuit to ground
Glow plug cylinder 2 open circuit.
Specialist seems to think it the air mass flow sensors at fault (......no sh*t sherlock! ), parts alone come to £318.64 plus labour!
To say Im not over the moon is an understatement, BUT, got 1 months warranty, so at least it'll get fixed at their expense! but I've had better starts to car ownership
summary
