Lets Hear From The Tuned 3 Series Brigade
developer
Volvo XC90 T8 Polestar c500bhp
An interesting "encounter" today.
A 58 plate 3 series, badged as a 320d, looking completely standard.
It could have been anything, however, it only had a single exhaust pipe, oval in shape.
Smoke each time it was gunned (DPF delete perhaps?).
3 people aboard - I was alone.
The only thing that made it look a bit different was a set of larger alloys.
A very very nice car in blue.
Now, here's the thing - it was quick, and I mean quick, each time he gunned it through the city streets.
I ended up behind it at a set of lights, and as they changed, he had the legs on me, despite my best efforts and him being 3 up.
Looking standard, I checked 320d outputs and he's nearly 100bhp down on me.
As I turned off he flashed his hazards, so clearly he's a bit of a petrol (diesel) head.
Any 3 series owner ideas?
ps - the "shouldn't be speeding through the city streets (I wasn't) will be ignored.
More than likely had a manual gearbox which will muller an automatic. Add to that the black smoke may mean it has had a remap and I doubt there'd be too much between you.
I was knacked by a 130 bhp Golf TDi when I was in my 177bhp E270 once.
Most depressing it was too.
Was the 335d available in 2008 , and the owner has a sense of humour ( hence the 320d badge ) .....
A mapped 335d is proper fast :cool:
It was a manual - I forgot to add that.
John
You travel in style and comfort. Speed is not the first priority as you have a Mercedes. Your car is fast enough.
Bet your MPG was better ....
Yes, mapped 335d will run easily up to 420/440BHP.
You can change Tailpipes -
I did on my 330D
I suspect this - I've been in 320d's before but not like this one.
Don't forget, I'm running 272bhp (claimed) so even mapping a 185bhp 2.0L shouldn't have had me struggling.
I appreciate a 3 is significantly lighter than mine, but he was 3 up.
335d has 2 single exhausts , 1 on each side
Did you manage to remember the plate, easy enough to check if 320 or 330.
335d has a pipe each side, I doubt a 335d owner would make it look like a 320d?
quick google..
The 184bhp can be tuned to 226bhp fairly easily.
So pretty nippy in a 3 series type car? power / weight
D3 Alpina perhaps?
350 max and they are dam dam quick. Brother in law had one and I could not shake it off with the e92 M3
Why assume it was an Oil Burner ??
Maybe but u can usually spot an Alpina unless it a serious Q Car Project
If you know what to look for, yes.
Its like compering B3 to M3, very much the same but so different.
Agreed
