You will need to buy new lights. There are also conversion kits available but from past experience on other cars they can really ruin the headlights should you take them off.
On newer models with the intelligent light system there is an option in the instrument cluster to change the lights over to lhd.
It normally is, I changed the whole headlight unit on a golf a few years back, involved taking the front bumper off but took no longer than a few hours.
Howdy Chris; I would generally class physically changing headlights as DIY, providing that you are OK with working on vehicles.
However you will certainly want to have them 'set' at a garage after the change, in order to then Pass the Vehicle Inspection for your location. (wherever that is?)
