I have a 4-5 year old "Tiny" laptop. It was well spec'ed at the time and is still a capable machine so reluctant to ditch it.
By well spec'ed, as a Tiny, it probably has poor quality components, not well suited to a powerfull laptop.
Problem is that it is prone to overheating & crashing.
It is still on it's original battery which is supposed to last 3 hours, but I'm lucky to get 1 hour out of it now. As a result it spends much of its time plugged into the mains.
With the battery on charge, more heat is generated, resulting in earlier crashes.
Do you think a replacement battery would solve a lot of the heat problems or is the machine destined for the scrap heap?
