Had the pump and the charger for quite a while. No problems with either.
Its ideal. Being a staunch supporter of road safety, i can, at the press of a button get chilled Chablis direct from the fridge in the boot, all without taking my eyes off the road.John
Do you use the pump to keep yourself and your good lady supplied with wine etc?
I bought one a couple of years ago, used it once, but second time I tried it would not work. I took it apart to see if I could fix it, but it looked as if it was built for 50p once you got inside, so just binned it.Had the pump and the charger for quite a while. No problems with either.
Just bad luck. 5 year warranty. Should have returned it. I have had mine for well over 4 years, 2 cars...oil change twice yearly.
Is that a plasma cutter for 80GBP?
Yep I was tempted, but realised I don't actually have a regular use for it or a compressor.
