alano
Found out the root cause for my drivers side light not working every now and then. My pure luck I lent on the dash board and found that the light went on. It was the fuse box when you open the drivers door there is a small fuse box. It seems when I move the front drivers light and reversing lights they go on and off. Going to have to remove fuse box and check solder jounts. Has any one had the same problems with this fuse box ?
Or is it knackered ?
Any advise before starting this job ?
