jc651
Got a small problem with my 2012 eclass......... the glovebox light and vanity light on the driver's side are not working but the passengers vanity light works. I have checked for power at both but nothing there so I moved onto the engine bay fuse box and they are all ok so I then checked the fuses in the boot and they are all ok. did a bit of a Google search and they said I also have a fuse box on the end of the dash but my car doesn't have one. Is there a hidden fuse somewhere or do you think it's a wiring fault causing this ?
I can live without them working but I'm a little worried that something else is not working that the engine needs and if it's just a fuse then it's a simple fix if I could find it. I also plugged icarsoft in but no faults found so I'm hoping it's just the lights that are out and nothing else..
Any help much appreciated
