Lights too bright?
Discussion in 'Electronics' started by John, Nov 2, 2011.
  1. John
    John Hardcore MB Enthusiast
    12,210
    Mar 3, 2011
    Daan Saaf
    Car:
    I wish.
    I've had cars with Xenons before but in the W211, I seem to get a few people ahead complaining I have not dipped my lights.
    Of course I can easily prove I have dipped my lights but I'm wondering if they might not be aligned correctly.
    What changed today is for the first time not only an on-coming vehicle flashed but an artic - which made me question it.
    It is soon to go in for a service but until then, I wonder if this is standard issue on a W211 with Xenons, or are these people just knobbers.
    They seem to be the right height when shining in the garage, and obviously being Xenons, they should be auto-levelling etc.
  2. andy27168
    andy27168 MB Enthusiast
    4,407
    Nov 27, 2004
    Southampton
    Car:
    1997 C230K, 1999 C43/55 AMG
    When you first turn your headlights on do they both raise then lower then go up into position as decided by the auto levelling system? It is quite common for the suspension link in the levelling system to break disabling the levelling system with the headlights out of alignment.
  3. SPX
    SPX MB Club Veteran
    16,106
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    Funnily enough, I had to adjust my xenons before my mot yesterday because they were aiming too high.
    I thought they just self-levelled?
  4. corned
    corned MB Enthusiast
    3,894
    May 2, 2008
    Living in error with Maude at Cap Ferrat
    Car:
    car
    They should.
    If the system is working properly, as stated above the lamps will perform a little curtsey as they start up (but you'll only notice at ignition on, not if the car's already running and you manually switch the lights on afterwards).
    The auto levelling arms are on the o/s suspension struts. I think one front and one rear. Easy to look under the arch (with the car on full right lock) and look up to see if the front's all correctly in place, but you may need to remove a wheel at the rear.
  5. @MARK
    @MARK Active Member
    756
    Sep 2, 2011
    Spalding, Lincolnshire
    Car:
    Audi A7 Quattro
    On the first time I went out in mine at night, I was driving along and cars were flashing me but worse, on 2 occasions, cars actually pulled over to let me past as I came up behind them.
    A quick visit to the dealer whilst they put them on the headlamp alignment thing and I have not had any problems since. Took all of 5 minutes.
    My previous BMW was the same when new.
    I am not sure if this is something that should be done at PDI but in any event, just drop into your dealer and get them sorted. Misaligned xenon lights are not good for anybody.
    Auto levelling however is all relative to the actual alignment. If they are set to high the self levelling will not compensate
    1 person likes this.
  6. SPX
    SPX MB Club Veteran
    16,106
    Aug 29, 2010
    Yorkshire
    Car:
    That one
    That's nearly word for word what the tester said....
  7. Red C220
    Red C220 MB Enthusiast
    4,197
    Jul 30, 2011
    Surrey
    Car:
    2015 SL400 : 2017 S6 Avant
    I've had a few people flashing for me to turn my lights down also.
    This is the first car I've owned that have xenon lights and I'm conscious they seem to blind other drivers.
  8. clever dicky
    clever dicky Active Member
    421
    Nov 27, 2010
    Car:
    Jag
    Can't you tell by looking at the pattern if you face a wall or shop window etc??
  9. @MARK
    @MARK Active Member
    756
    Sep 2, 2011
    Car:
    Audi A7 Quattro
    If people are flashing you it's probably because your lights are set too high.
    Pop into your dealer and get them sorted ASAP because for one, it's not fair on other drivers and also you don't need other drivers flicking to main beam in retaliation so you can't see either. The dealer will/should sort this without question.
    And finally, it's a moving vehicle offence and MOT failure. A police officer could pull you and give you a fine or at least a vehicle rectification notice which is not what you expect on a new car.
    With great lights comes great responsibility.
  10. renault12ts
    renault12ts MB Club Veteran
    16,122
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    A good test...if you can light the tops of the hedges...too high.
  11. Red C220
    4,197
    Jul 30, 2011
    Surrey
    Car:
    Mine are set just fine, they are just so bright.
    Couple this to driving on undulating country lanes, the nature of the road means you have a 50/50 chance of blinding the oncoming traffic even with correctly set lights.
  12. @MARK
    @MARK Active Member
    756
    Sep 2, 2011
    Car:
    Audi A7 Quattro
    Have you had them checked on a proper headlamp alignment rig?
    No matter how bright they are (remember I have the same lights as you and I do not get flashed any more) they should not be causing problems for oncoming drivers.
    If they are flashing you it's because you are blinding them.
    Please get them checked.
  13. Red C220
    4,197
    Jul 30, 2011
    Surrey
    Car:
    It's quite obvious from the light pattern that doesn't even shine above the boot lid when following a car.
    Hit a bump or rise in the road and it doesn't matter how well your lights are set, it blinds on coming traffic.
    For the record this only happens on unlight local roads.
    Having never had a car with xenons previously maybe I'm just more aware of it at present.
  14. jefrs
    jefrs Active Member
    617
    May 30, 2010
    Berkshire
    Car:
    S210 E320 Avantgarde '98 full load
    Just a thought, if the vehicle has self levelling suspension, then the engine needs to be running when the beams are adjusted.
    The beam levelling also replies on the engine running.
    So if the beam is adjusted with the engine off, the beam rises when it is running.
    We see xenons flash then dim then brighten and rise when they are switched on.
  15. @MARK
    @MARK Active Member
    756
    Sep 2, 2011
    Car:
    Audi A7 Quattro
    If they are just below the boot lid when following a car then to a car coming in the opposite direction, until they get to within 10 meters of you, the light is straight in their face!!!
    The edge of a boot lid on most cars is higher off the road than your headlamps which means the beam of light is pointing upwards.
    The further away you are (e.g. oncoming car) the higher the beam so you are getting it right in the face until you get pretty close. Having super bright xenon lights just compounds the issue.
    YOUR LIGHTS ARE TOO HIGH!
    Please get them adjusted
    Correct!
  16. stroudwaterboy
    stroudwaterboy Member
    52
    Aug 23, 2011
    Gloucestershire
    Car:
    W204 250cdi sport
    Whilst on my way to our local town a couple of nights ago I had a car with obvious Xenons coming towards me, it's the type of light that gives it away.
    As all the traffic cars in our county have Xenons you tend not to flash them of course.
    I then spotted as it went past that it was a C-Class sport looking identical to the one I have on order. From the beam pattern on the road the alignment was spot on, it was just the light is so bright. This has concerned me since but nothing I can do about it now!
  17. OP
    OP
    John
    12,210
    Mar 3, 2011
    Daan Saaf
    Car:
    I wish.
    Hmm, good question. I will try it tonight when I leave!
    Fortunately, Mercedes photochromics work incredibly well so it doesn't affect me but the fact they think they are on main beam when they aren't means it needs investimagation.
  18. evdok
    evdok MB Enthusiast
    2,519
    Sep 26, 2006
    Stourport
    Car:
    BMW 330D xDRIVE M/SPORT INDIVIDUAL
    Mine just go up and stop:confused: none of this dance other xenons do!, night vision is good as normal.
  19. mr. shr
    mr. shr MB Enthusiast
    1,879
    Apr 22, 2004
    Mine don't always do the dance. I think (will need to investigate this) that they DON'T do the dance if the car in on an incline at start-up.
  20. OP
    OP
    John
    12,210
    Mar 3, 2011
    Daan Saaf
    Car:
    I wish.
    Well, I turned the lights on with the engine off and again with it on... nadder.
    I seem to remember my previous Saab's lights doing a small dance now.
    I'm none the wiser but it will be investigated shortly.
    I now suspect very much they are not right though as the Mini Cooper S I followed today will testify.
Tags:
Share This Page
