Hi All,
I changed the gearbox oil a wee while ago but I couldn't drop the pan due to a stubborn bolt...
The car was acting weirdly after a while. Not moving while engine revving and once in a while I was in Limp mode...
I looked at the oil, it was bad, like the old one...
Then I was told I need to change the filter as it might be clogged. Fair enough, looking at the state of the new oil there was something dodgy there...
I then attacked the bold, dropped the pan,
change oil ( with the proper MB stuff),
the filter,
and also the plug as it was very wet...
From there she still wasn't right, running but not right.
The next day I looked at the gearbox module under the hood and it was a little wet, not much at all, I have seen worse.
Clean it nicely and put it bak.
Then boom, after a wee run she just didn't move out the limp mode.
I am stuck on second gear, no matter when I do, when I am on park or neutral I cannot rev the engine more then 1000 Rpm.
Since yesterday I got once in a while all the BAS/ ECP/ faulty brakes etc ... coming up. But not all the time. Think I got it 3 times. Clear it self after a restart.
The onboard diagnosis do not see any fault at all? Does the onboard diagnosis see all the fault?
Today I took the plug out to make sure it was in place properly.
Now, is there a magic trick to stop the limp mode or its a star only?
Any help would be great
Beers
I am now recharging the battery as it might be the cause for the BAS etc... thingy. Just a thought.
the filter,
Beers
