SVAMG
Evening
I need advice from you all if you ever encountered any of the following codes:
CODES
1. P010106:
2. P013392;
3. P228100; and
4. P024872.
SYMPTOMS
Car is stuck in limp mode even after the codes are cleared and will not go past 3,000RPM.
A few months ago I had the DPF cut, EGR coded out and a stage 1 re-map was also done. The car was fine for a month and drove really well then one day on the way to Bradford (whilst in heavy traffic so not being able to drive at a continuous speed) the vehicle went into limp mode. I took it back to the garage and cannot remember what was done but the car was fine as long as I abused the accelerator. I noticed whenever I put my foot down a lot of black smoke would come out from the back.
Now the vehicle is stuck in limp mode and my mechanic is unsure as to what can be done. I believe I've burst the boost hose but not sure.
Any help is greatly appreciated.
CODES
1. P010106:
2. P013392;
3. P228100; and
4. P024872.
SYMPTOMS
