- Nov 29, 2002
- Location
- London\Essex
- E63s s213 2019, E55 2004 Silver-SOLD, E63 w212 Weistec AMG-SOLD, E55 2004-SOLD, C36 1997-SOLD
When i purchased my E55, Linguatronic was one of the 3 items that wasnt installed from factory.
over the last few months I have been researching the install and gathering the parts needed, surprisingly the w211 had 3 different types of parts depending on year of build, finally got the correct parts, and ive finally got it all working.
heres a quick summary of what needed to be done;-
parts needed
- New cruise control module (with Voice control hole)
- Voice control lever
- Steering cowel covering
- Voice control lever cover
- Wirning Harness
- MOSt fibre
- Linguatronic control module (this is the most expensive part)
- screw
install
- to install the new Cruise control module, the steering wheel has to be taken off, all the contact spring\clock spring\stalks all dissasembled, new part replaced and them put back together.
-Remove boot trim and left side rear bolster trim, secure the VC unit with screw, attach wiring, splice power, ground and wakeup to phone controller wires, run the microphone wires into rear bolster area, unplug the phone mic plug and plug in VC mic plug.
- Connect to MOST fibre ring
- coding on STAR
I was going to do a detailed how to, but as the install was done in bits and time was short i didnt - also the fact i was nervous enough taking some bits apart as it was without taking pics!
tbh, if I hadnt got the control unit cheap, it would be cheaper to go to Alfie@comand as this was a tricky install due to the delicate parts you can damage in the process, also the access to STARis essential which i borrowed off my indie (who is a good freind).
Many thanks to Richard who gave me all the missing info, and to Alfie, Miro and MbenzNL for overview on parts.
now i have to learn how to use it
parts needed
- Wirning Harness
- MOSt fibre
- screw
install
- coding on STAR
