Linguatronic module part numbers
Paul Grainger
UK
SL55, Porsche 996 C2 convertible
Does anyone (possibly with access to EPC) know the correct part numbers for a 2005 (ie MOST bus) linguatronic module for a R230 SL?
Alternatively...... Can anyone confirm that module A203 820 7585 is suitable for this car?
Thanks to anyone who may be able to provide this information...... My retrofit project is stalling!
Paul G
Alfie
Surrey/Cotswolds
W169 A, W205 C, W451 smart
Paul G
That will work in the car but its an early part and has been superceded twice since production.
OP
OP
P
Paul Grainger
UK
Thanks for replying Alfie. Do you happen to know what the 'newer' part numbers are?
Can you confirm that A211 820 6285 is not compatible with this car? I've got one of these and it doesn't seem to work. It would help if I could confirm that it doesn't work due to compatibility issues rather than something else on the MOST network.
Thanks again
Paul G
richard
Berkshire, UK
MY04 SL55, MY18 GLC63s
It should work. Can you see it on the MOST bus ? When they fail, they tend to fail leaving the fibre looped properly, and then your phone won't work as the microphones connect to it and not the phone controller
OP
OP
P
Paul Grainger
UK
Richard - the phone is working fine through the A211 820 6285 module and there are no errors showing, the MOST loop is in the correct sequence, and the rest of the audio systems are all ok. When I pull the VCS lever nothing happens and its looking more and more like the VCS module that I have may have compatibility problems.
OP
OP
P
Paul Grainger
UK
I have the chance of a A203 820 7585 and I really wanted to know if this would work with my car, and that the reason the VCS doesnt work at the moment is because the existing module is not compatible. I don't want to spend money on another module if it's still not going to work :(
Paul G
Alfie
Surrey/Cotswolds
Paul G
That part is listed as suitable for your car.
OP
OP
P
Paul Grainger
UK
I would like to say a big 'thank you' for the messages and help that I received with this project. The VCS is now working perfectly following the replacement of the VCS module with one that is compatible with the car.
Particualr thanks to:
Richard
Diesel Benz
Alfie
Happy Benzing!
Paul G
