if you can pick up a 2nd hand unit thats your best bet, its a mine field out there tho.
i retrofitted the option for about £500, that was with a new cheap module.
Did that include the activation stalk? The 221 would be a bit cheaper since it already has the steering wheel button.
what about on a w210?
Hello,
I own W221 2006 EU edition - almost full option with no linguatronic. My sterling wheel is equipped with buttons. What I need to buy ? I assume Linguatronic ECU/module - I can order in very good price module A2218703387 - I need advice if this will work with my MB (can be used module reprogrammed to my car using StarDiagnose) ? Will be any additional wiring harness required or Mercedes is factory equipped with full cabling ?
Can some of experienced users write steps required to retrofit Linguatronic ?
My mechanic has StarDiagnose - programming will not be an issue (I hope).
Thank you a lot.
